'09 stock klx250s & glowing red header
Wow, thanks for all the replies! Sounds like it's normal for a stock bike with all the smog crap and stock jetting. I am sure someday I will be changing things, but it will have to stay stock for awhile. Just wanted to make sure it wasn't hurting anything. From past experience, bikes do tend to run lean from the factory. I know about 99% of you guys have modded your bikes, but is it worth re-jetting a completely stock bike? I see a lot of people are changing the main jet, but they also have slip-on's airbox mod, etc.
Do a search. You'll find plenty of info on it.
i had the same issue with my '09. the dealer told me that it was kawasaki runs 'em lean from the factory to pass emissions. the carb setting is fine for some people, but its to lean. the dealer threw a 38 pilot jet in mine and it runs way better
The only two times my header ever glowed was when I left the choke out and fuel switch off. Stupid me, never do that again. The second time was when I was racing across the desert at over 8k rpm's for over 30mins.
