09+ speedometer adjustment
Old 03-25-2011, 04:32 PM
Ckahleer's Avatar
Default 09+ speedometer adjustment
Does anyone know of a way to adjust the electronic speedometer on a 09 KLX250s. Mine reads about 11% high?
Would a sensor from a KLX250sm reduce the reading too much?
I found this adjuster online but question if it will work on our bikes.
Electronic Speedometer Adjustment Module for Sportbike and Metric Crusiers.
Craig
Old 03-25-2011, 04:47 PM
ol'klx-er's Avatar
yeah, my '09 is 10% over all the time (checked by GPS). I think they all are. Think of it as a (no)speeding ticket safety. It's pretty easy to subtract 10% to know how fast you're really going. I wouldn't waste any money to "fix" this issue.
Old 03-25-2011, 05:06 PM
TexasKawai's Avatar
I have used the Speedohealer on my 954RR and VFR800 with great success. They make one specifically for the KLX.
HealTech Electronics Ltd. - Makers of the SpeedoHealer, GIpro, X-TRE, FI Tuner Pro, OBD Tool
Old 03-26-2011, 01:13 AM
linkin5's Avatar
Below about 40mph my spedo is off the other way then as you get above 40-45 it swaps and reads high but it isn't the same throughout the range.
Old 03-27-2011, 05:29 PM
cmott426's Avatar
I have this one, 12oClockLabs $79 and it is plug n play for the KLX.
Works perfect. I have had it for over a year now.
Old 04-02-2011, 03:05 PM
Ckahleer's Avatar
I found the p/ns for the speedometer sending unit for KLX250s and KLX250sf are the same, however the meters have different p/ns.
Is it possible there is an adjustment screw inside the meter.
I doubt they build a different meter for the sf. Its probably the same meter, just calibrated differently.
I may go with the 12oclocklabs calibrater, But want to make sure the stock meter is not adjustable first.
Craig
Old 04-02-2011, 03:43 PM
T_i_G_e_R's Avatar
take it apart Craig let us know what you find
Old 04-03-2011, 05:44 AM
CHASE's Avatar
Craig
I dont think the calibration has anything to do with the difference I think the reason the part# for the meters are different is the SFmodel has blue led backlight and the S model has amber led backlight!
Old 04-03-2011, 11:31 AM
David R's Avatar
Post
The S has a 21" front wheel and the SF has a 17". Something has to be different.
David
Old 04-04-2011, 09:06 AM
maninthesea's Avatar
David
Maybe thats why they display in different colors, to make it obvious which bike the display is calibrated to.
Cheers, Jim
Quick Reply: 09+ speedometer adjustment
