09 klx250s
Old 08-03-2008 | 09:15 PM
barthel75's Avatar
Default 09 klx250s
if i buy excel supermoto wheels and spokes can i lace them to my stock hubs
Old 08-03-2008 | 09:33 PM
GreenMonsta's Avatar
I believe you can although I havent done it myself. If I remember correctly the stock hub is 36 spokes so make sure you get the right rim. I got a 98 kdx200 F. rim and a 94 KLX250r R. rim for 200$ off Greed Bay. It's a bit more money up front but if you can find a second set of wheels then you can swap em in minutes.
Old 08-03-2008 | 09:35 PM
barthel75's Avatar
thank you for the info i wish i could just get a hold of the ones for the japan model i work for a kawasaki dealer and can get a hold of them
Old 08-03-2008 | 09:40 PM
barthel75's Avatar
one other question i no parts unlimited and tucker rocky carries the supermoto front fender in red has anyone used this and does it match the kawasaki red
Old 08-04-2008 | 01:42 AM
kgwld1's Avatar
Stock hubs to excel rims here you go.
Old 08-04-2008 | 01:50 AM
barthel75's Avatar
so you used them did you use the stock brakes and rotors
Old 08-04-2008 | 01:59 AM
kgwld1's Avatar
Bought a second pair of everything bigger front rotor and tires rear rotor bearings and powercoated hubs. Have all the stock setup for dirt setup.
Old 08-04-2008 | 02:01 AM
barthel75's Avatar
can i use the stock stuff i wont barely hit dirt i use my kx250f for that i just use this cause my silverado uses to much gas now i work for a dealer i can get the rims and spokes from parts unlimited or tucker rocky cheap
Old 08-05-2008 | 01:41 AM
barthel75's Avatar
I no you used the excel rims and stock hubs but were did you get the rims with 36 holes every one i find is 32 holes
