09 KLX 250 Running Crap
Old 11-20-2013, 03:05 PM
Ant's Avatar
Ant
Ant is offline
I think it will be FI. Mine is 2009 from the uk.
One of these bad boys should be an easy fix if your bike is running too lean,
Oxygen o2 sensor eliminator Kawasaki KLX250S KLX 250 S/SF EFi | eBay
View item:
Old 11-20-2013, 03:06 PM
Brum's Avatar
TNC mate fair one I do agree, but in my defence I've had this bike only a few days and I don't now much about this bike yet as I have no manual or anything, all my other on/off road bikes DRZ400 XR 400 have all been carb so wrongly I assumed this did with out really looking.
Assumption is the mother of all fxxk up's..
As always thanks
Brum..
Old 11-20-2013, 04:03 PM
Brum's Avatar
Yep...... It is FI....... Moral of this is check first....... Ant thanks for the recommend will check out, any other recommends welcome.....already had the one about take to mechanic!!!!!
Just read a very interesting post on here ref the ECU problems with the FI model of the KLX????
Cheers all.
Brum.
Old 11-20-2013, 07:08 PM
Scotty452's Avatar
I bought one to. They have the stock exhaust with the guts and baffle removed. Mine is the same, it backfires when cold due to the fuel enrichment from the ECU until it is warm (auto choke). After it's warm it runs fine. It will also hunt a little when cold due to the same. Have you had it out for a blast, and how dose it run when warm?
Old 11-20-2013, 07:13 PM
Scotty452's Avatar
Share the link to the ECU fault as you say it may be an interesting read. These bikes had the Kawasaki mods done which included water ingress in the ECU!
Old 11-20-2013, 07:25 PM
Brum's Avatar
Scotty mate not really been for a good blast as not yet road registered but the bike was at temperature when hunting and cutting out.
Check out the links.
https://www.kawasakiforums.com/forum...-lights-31106/
https://www.kawasakiforums.com/forum...fi-mods-32409/
How are you getting on with registering ?
Cheers Brum.
Old 11-20-2013, 07:35 PM
Scotty452's Avatar
All docs are sent off, however DVLA sent them back on Monday as I forgot to send a copy of my licence. It's a bit of a pain to get the paperwork required but it's done now, should have reg plate by next week as the original paperwork was processed in 2 days.
Old 11-20-2013, 07:45 PM
Brum's Avatar
We are nearly there just got the bikes MOT'd then going to send of the V555's. Had to contact Kawasaki UK for the certificates of conformity.
Did you send photo copy's of licence or oringals?
Cheers
Brum.
Old 11-20-2013, 07:47 PM
Scotty452's Avatar
Ant have you got a O2 sensor eliminator on your bike and if so what advantages dose it give?
Old 11-20-2013, 07:49 PM
Scotty452's Avatar
You will also need a letter from kawasaki to prove the age of the bike or you will get a Q plate, this has a cost of £55
Quick Reply: 09 KLX 250 Running Crap
