07 KLX250s Problems
Old 02-08-2011 | 01:31 AM
Branderson92's Avatar
Default 07 KLX250s Problems
'm fairly new to this.. but how does one even check the CDI or crankshaft sensor? I have an 07 KLX250s and i have no spark whatsoever, it turns over, just no spark. I've tried multiple spark plugs and its the same regardless. I've determined that the problem is somewhere between the ignition coil and the Igniter. How to isolate or even know how to get a solution once found. Help please.
Old 02-09-2011 | 10:55 PM
jeff025's Avatar
I had kinda of the same problem with my 06. According to the service manual the only way to check the cdi is with a new one. To check the crank sensor or pickup coil is to unplug it from the connector, white one i think, and check the ohms. The same method is used for the coil as well. After you check everything and find out the cdi is the problem I have a brand new in box, never used cdi for sale at a good price. I bought a new one but it wasnt the problem.
Adrlnjunkie
01-10-2011 08:16 PM
edhammac46
01-06-2011 08:29 AM
bmrconstruction
01-28-2009 11:23 AM
6SLF157
08-27-2008 04:05 PM
jonathanneely
07-27-2008 01:02 AM
Quick Reply: 07 KLX250s Problems
