06 klx stalling out at half a tank
Hi, I just got an 06 250s with 12,000kms on it and twice now when I get to about 100kms on the tank the bike won't stay running, keeps stalling out on me, I fix the problem by filling it back up with gas, but I know that's not the problem, since it still has like a half tank of gas left. Only thing I can think of is when I open the tank and close it again if that's doing something.
My question is, do these bikes have a petcock or equivalent and if so where is it so I can check it and what do you guys think about that being the problem?
Next time it dies, try switching the petcock (LH side of bike) to reserve position (lever straight-up -180 degrees from 'On' postion). If it runs fine after that, the standpipe for the main might be a bit high, or you just get REALLY crappy gas mileage for some odd reason. Are you riding on pavement or mostly wringing it out off-road?
SC, would like to know when your modded bike reaches reserve. Sounds like you're getting pretty decent milage.
I fear you are right, that I burned 1.5 gallons in 53 miles which is about the consumption of my old XR400 in the same consitions. The tank was topped off before I left and odometer reset. This was the bikes first real tank of off-road and I always start with a full tank. I actually carry fuel hose and planned on being able to transfer fuel to riders that ran out, thank goodness I didn't do that!
The trail was really tough and all single track. I had several times that the cooling fan kicked on while I was riding and it was about 50 degrees ambient. So I am going by the theory that when you use these bikes to do work you will use lots of fuel, when you cruise on the pavement they are very miserly with consumption.
jhoffy22
10-09-2011 06:02 PM
