Are 06 & 09 seats interchangeable?
Old 07-03-2010 | 05:01 AM
maninthesea's Avatar
Default Are 06 & 09 seats interchangeable?
Does anyone know or could someone physicaly test if 06 & 09 seats are interchangeable. Part #s are simular but not same but that could just be cosmetics.
Would apreciate so I can send Wild Will some $
Cheers Jim
Old 07-03-2010 | 05:22 AM
wild will's Avatar
I will go to my Kawie dealer in the morning and take the one of the 09sf they have and see if the 07 will fit? He treats me good cause I treat him good, too good!
Unless someone knows before I go.
Oh it's morning already, didn't even realize it, got to get some sleep.
Old 07-03-2010 | 04:43 PM
wild will's Avatar
Thumbs down 06-09 seats are not interchangable
Sorry no go.
I tried to make it fit but the gas tanks are shaped different. 09 seat is flatter up front and 07 wraps around side of tank more. Makes sense now because we knew the tanks were different between the years, so the seats are too.
The back portion of the pans look the same just the fronts different.
09 seat straps are bolted to frame, 07 are bolted to bottom of seat.
09 took 8 bolts to get off seat, only 2 for 07.
Good Luck!
Maybe just strap a pillow to the frame for a month? Ha Ha
Old 07-03-2010 | 09:46 PM
Thanks Will. Only hope for me on this front is if IMS makes a tank that fits both bikes.
Cheers Jim
Old 07-04-2010 | 06:19 AM
punkenduro09's Avatar
my 09 only takes 2 bolts to get the seat off, or im way to high on medical cannabis. from what ive seen, i think an 09 seat will fit a 06-07, but not the other way around, but whats the point really? maybe if you have a acerbis tank on an 09, it might work with the 06-07, which would get rid of that gap where the seat would be, but for some reason i really like the 09s seat. its firm but not overly, and grippy but not like super glue.
Old 07-04-2010 | 04:15 PM
wild will's Avatar
I took a seat off a new 09 250sf. I had to remove the 2 side covers first to get to the 2 bolts that hold on the seat strap to remove the seat completely. Is the 09 s model different than the sf? Maybe I was too high on homegrown?
I think the 09 may fit the 07 but he wanted the 07 to fit the 09.
Old 07-04-2010 | 11:17 PM
Yeah I was looking for a seat to have custom built so I am not bikeless if I want custom seat.
My 09S did not have a seat strap and I cant remember haveing to remove one from the GF's SF but I am sure it does not have one now.
Cheers Jim
Old 07-05-2010 | 03:50 AM
you got me with that seat strap. i took that off in the first week, havent really thought about it sence. otherwise, 2 bolts.
Old 07-05-2010 | 04:30 AM
wild will's Avatar
Cheers Jim
Man I feel stupid!
Maybe it does fit your bike?
Old 07-05-2010 | 05:06 AM
wild will's Avatar
Ok was on the kawy site and looked at the 09 & 10 250s and 250sf, they both have seat straps that are bolted to the frame from the side. See for yourself, click on seat.
https://www.kawasakiepc.com/SystemSe...TOKEN=74368030
The 07 doesn't have seperate straps that bolt to the frame, they bolt under the seatpan.
Two totally different seats those SOB
tramatbay
KX250 & KX250F
05-14-2020 02:42 AM
crf230
05-06-2009 07:31 PM
zx7rss1
07-05-2008 05:42 AM
noimad1
KX250 & KX250F
07-10-2007 10:37 PM
Whiteman
03-20-2007 11:44 PM
Quick Reply: Are 06 & 09 seats interchangeable?
