06/07 suspension on an 09+ bike
Old 05-23-2016 | 09:44 PM
MattyTracks's Avatar
Originally Posted by zomby woof
So I've had a few really good rides on it now and I'm really happy with it. The bike does sit higher, but I'm not exactly sure how much. I forgot to take those measurements before I started. Ground clearance is increased, which is one of things I wanted to accomplish. If somebody wants to take some measurements on their 09+ bike, we can compare.
It handles great. I've never been as fast on this bike as I have been on my last two rides. Not even close. The rear spring rate is just barely enough for me at 145lbs. Sag is set at 85, and I might tighten up a bit to 75. It is bottoming, but only on fairly extreme sections on thee trail, and high speed. On the MX track, it doesn't take much to bottom, but that's not what I'm using it for.
12 mm preload spacer in the forks, 3W (same as 5) oil at 100 mm, forks up in the triples 15 mm, and sag at 85, it feels very balanced like it never has before. I would say if you do this swap, unless you're under 150lbs, I would use the 300 spring. Also, where I have the forks set, and considering that the travel gain is only about .5" or so, I might just stick with the stock forks.
Good stuff, couple questions. Are you using the 300 Swingarm? Will the 300 Swingarm bolt in a 09+ 250? Is the 300 Swingarm aluminum? Is there any dimensional or weight differences between the 250s and the 300 Swingarm? Are the 300 triple clamps different vs the 250s? Angle/offset
Thx
Matt
cegusman
05-26-2012 12:24 AM
lstoker
08-22-2005 06:16 PM
ezcruz
08-19-2005 09:59 PM
TATTOOZIT
07-07-2005 06:30 AM
Eckardt
06-06-2005 02:50 PM
Quick Reply: 06/07 suspension on an 09+ bike
