09 Rear Disk Guard template is finished.
#31
I will be able to place an order if I can get only 5 people to commit. Slightly higher price to get them cut but I won't add that to the $70.
Or I can provide a template that is made from vinyl and will be cut using a CNC vinyl cutter. Just peel and stick the template on the material you want to make it from and cut it out. I will provide hardware also, for $25.
#32
Is this rear disk guard done/for sale??
Next step is to cut it out of .190 aluminum. IF this works I will then have it CNC machined.
It is not like most, it is just a plate and not a full replacement for the brake holder assembly. I will also add some cutouts to reduce the weight and make it look a little better.
#33
My contact info
