"Grease Trick" for Oil Filter Spring
Old 09-06-2006 | 07:33 PM
LordVngr's Avatar
Default RE: "Grease Trick" for Oil Filter Spring
ORIGINAL: deej
Why doesn't Kawasaki just have the spring welded on the filter and charge another 25 cents each? I really think they dropped the ball on this one. Has anyone ever seen anything like this before?
I believe my Suzuki dr250S was like that but cant remember for sure. I just use a little dab of white greese to hold the spring in place while I install the filter. Dont think its a big deal as long as your using just a Little dab. Id rather do that then lay the bike on its side.
LV
Old 09-06-2006 | 10:25 PM
Firedude's Avatar
just did my first oil and filter change , i just put the spring on my filter and put it in place super quick lol
Old 09-07-2006 | 08:46 AM
oregon dual sport's Avatar
The first time I think I tilted the bike, then I realized that I could put the spring right in filter without any problems. I think it's because on the second oil change I used a different filter.
Old 09-07-2006 | 10:49 AM
Funny thread, when I was doing my first oil change, I was like WTF. I considered Firedude's technique of "super quick" but I decided to consume a carbonated adult hop beverage or two and think about it. With my inhibitations slightly reduced I tipped the bike over and just installed it. But I wasn't about to post my technique on this forum ....... I'll try a little grease next time which NEEDS to be this weekend. LOL
Old 09-08-2006 | 12:55 AM
954ken's Avatar
I hold the bike over my head with one hand and put the spring on the filter and install.
Old 04-26-2012 | 11:30 AM
kojack06's Avatar
Someone, really clever, on another thread, mentioned that he simply took a pair of needle nosed pliers and expanded one end of the spring so that it sits under tension in the little receiving pocket inside the case. No more issues. I think I am going to do that next oil change.
Old 04-26-2012 | 01:26 PM
redpillar's Avatar
I gave the spring a twist and it stays in place all the time.
Old 04-26-2012 | 02:45 PM
Websurfing101's Avatar
I used a very small amount of super glue to hold the spring to the oil filter.
Old 04-26-2012 | 02:55 PM
You guys realize this thread is from 2009? its also started by the guy i went to FL with.
Old 04-26-2012 | 03:18 PM
rgoers's Avatar
Wish I had my KLX during the 2 years I spent in hell... er, I mean, Florida. It would have made the time pass that much quicker.
Quick Reply: "Grease Trick" for Oil Filter Spring
