idle problems
idle problems
I've got a 94 Vulcan 500 (maybe I should be in the classics section?) that recently started idling very low (and frequently stalling, and sometimes having trouble restarting). As long as I keep a little pressure on the throttle, things seem to be fine, but if I let go, it may stall out again.
I took it to a mechanic, who thought it was the ignitor, but after replacing that, the problem has not gone away. I should mention that it is intermittent so it doesn't happen all the time. Anyway, I'm going to try adjusting the idle up a little and see if that solves the problem.
If anyone has another suggestion, I'm all ears.
thanks,
thanks,
Born2Drive4Ever22
10-25-2007 03:50 AM
