Help!!!
Help!!!
I have a kawasaki 300 Bayou i was cleaning the KEIHIN CVKcarb becasue the atv has been sitting for about 2 yrs well after i everything was clean inoticed on the fuel inlet elbow part that goes into the carb had a little crack on the bottom... i need to know if maybeJBWELD could fix the problem or do i need to go buy a new carb that is going to run me about $300.00. so if anyone can help please do.. Thank you Robert
RE: Help!!!
I would try that grey two component clay like stuff, it comes in a clear tube and you cut off what you need then combine it or knead it with you're fingers to mix it, I have used it on my gas tank on my BF650 and also on the fuel tank of my generator when the gas froze and it worked like a hot damn, can't remember what it's called but I can almost bet that Home Depot or, Napa would have it. It's a grey compound in a clear tube,
