Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
250cc bayou smokes
Old 02-12-2008 | 01:21 AM
kevdesh4's Avatar
Default 250cc bayou smokes
I have a question. My girlfriend sunk my new 08' 250 bayou. I immediately drained the oil and changed it 8 times. I went out and ran the bike for a weekend and it ran perfect. Although i noticed a small amount of smoke when you really floor it. In idle it has no smoke. I was wondering if I need new rings or it may just be something I didnt notice before.
Old 02-14-2008 | 08:49 AM
whitehendrix's Avatar
Default RE: 250cc bayou smokes
a wet and dry compression check will tell you what you need.
do a dry test and note the pressure, then pour about 2-3 capfuls of ATF or motor oil in the cylinder and do another comp check.. if the value is significantly higher, new rings may be a future investment.. a wet test will always raise the comp pressure, but if its over another 20% or so, its rings. if theres no difference, then that points to a valve or gasket leaking..
smoking under hard load can be a bunch of things.. could be a clogged breather, leaky valve seal, or the oil rings... each one tho is an easy find thrru process of elimination.
Welcome to KF, btw..
good luck bro! keep us posted!
xrjoe
06-23-2014 11:17 PM
WeaSiL
06-12-2008 04:05 AM
Russian Rocket
01-07-2008 01:50 AM
LearjetMinako
08-31-2007 09:57 PM
dunndilly
03-31-2006 10:36 AM
