Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
2005 250 bayou tapping noise exhaust side
Old 07-30-2010 | 02:14 AM
theblaze22's Avatar
Default 2005 250 bayou tapping noise exhaust side
i have a 2005 kawasaki bayou 250 it got rolled into a creek and hydrolocked braking the intake rocker replaced it with a new one it runs great lots of power but has a metal to metal tapping noise i think its coming from the exhaust rocker if i pull up on the compression release it gets better what is going on please help..... if I take out the compression release its still noisey.. played around with all day if anyone has any ideas I would like to hear them. yes vavles are set correctly can not see anything wrong had head off to inspect did not see anything out of the norm...PLEASE HELP I NEED TO GET THIS RUNNING RIGHT
Old 07-30-2010 | 04:24 AM
If your leak down test proves that your valves and rings are holding.....are you sure that the noise is not the CCT needing adjusted again after the rebuild? Just a thought, good luck and welcome to KF
edit: CCT= Cam Chain Tensioner
Petey2804
10-14-2008 06:53 AM
Surago636
04-14-2008 07:29 PM
dcorlando
03-12-2008 11:10 PM
dcorlando
10-10-2006 11:52 AM
reg
05-29-2006 12:36 PM
Quick Reply: 2005 250 bayou tapping noise exhaust side
