quarts of oil? help
quarts of oil? help
hi this is my first post here i just picked up a 1988 bayou 220cc w/ electric start and the p/o told me 2 quarts is what he put in the engine every oil change? but when its running i don't the little eye filled up like it is when cold, or not running, i just want to know if i have enough oil in this thing, someone please help me out...thank you
RE: quarts of oil? help
And when you check the manual for the capacity, don't forget that "liters" is not "quarts!!" Don't be tempted to empty the bottle just because "it's close enough." Put in the correct amount. If you add too much, you'll get equally nasty results just as if you added too little. The proper amount should be about 1/3 to halfway up on the sight glass.
Icantrideabike
09-22-2006 02:58 AM
Jutboy
04-21-2006 06:05 PM
