Mule transmission swap
Old 01-09-2019 | 05:26 PM
Rick Boyster's Avatar
Default Mule transmission swap
Just got a 2002 Mule 3010 4x4, it came with a 2wd transmission. Is the 2wd compatible with the 4wd minus the trans case thing. Are the gear ratios the same, the 4wd transmission has metal shavings in it so not sure what condition it is in and was hoping to swap it with the 2wd and just add the 4wd transfer case part.
Thanks for any help
Rick
Old 01-14-2019 | 09:31 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
or this one is even more focused:
https://www.kawieriders.com/forum/
Paul Leischner
01-14-2019 09:32 PM
Braddodd
10-05-2018 10:38 PM
waterbuff
01-25-2018 04:48 PM
sgtlane04901
01-25-2018 04:43 PM
gormally
01-25-2018 04:42 PM
