Mule help
Mule help
hello, I am new to this forum and new to Kawasaki Mules. I need some help. I picked up a 1993 2510 4x4 KAF620A1. I ran ok when I got it, started pulling it apart, Cleaned it up. apparently I wiggled a few too many wires. while on the lift I tried to start it again, No spark...zero. I then started looking and wiggling, one of the wires coming out of the pulsing coils separated, I spliced it by bypassing the plug. tried to start it again. it started but only the rear cylinder would fire. So I bypassed the plug all together. Still nothing
I since tested both ignition coils and the ohm good, I pulled the pulsing coils out and tested them, they both ohm good. I re-connected the wires to the pulsing coils, and re-installed. Unhooked the battery and put in a new Ignitor, still no spark to front cylinder. I tried to order new pulsing coils...........they are obsolete, discontinued, but my hunt is still on part # 59026-2062.
I did find a set of used pulsing coils but I am doubtful this is my problem.
I have a manual and all my tests so far fall within the parameters. Any suggestions ?
txbuckhunt
08-04-2019 11:36 PM
