Mule 2510 Ignitor signal to Fuel pump relay
Working on a fuel pump relay issue and I need to verify what signal I should expect from the ignitor to trip the relay. I am getting no voltage out of the BK/BL wire on the relay.
I have 12v power in the BK/W wire from the key switch and I am seeing 12v on BL wire from the ignitor (without the motor running or cranking). Is this correct? I would expect that there should be no voltage from the ignitor when the engine is not turning?
I replaced the Fuel pump relay thinking that would fix the problem, but it has not. I am now suspecting the ignitor? I suppose I could have gotten a bad relay.
Any suggestions?
Any suggestions?
