2001 Mule 3010 Carb Cleaning Advice
Good morning all....new to the forum here. I have a 2001 3010 Trans 4x4 that is generally well maintained, but does sit for periods of time. The last time I started it I couldn't get it to idle. It will rev up, but if I hold it full throttle it will "bounce RPM's" up and down. If I let off a little bit and hold it about 3/4 throttle I can get it to run steady, but as soon as I let off it will die. I am sure that the carb bowl/jets etc need cleaning, but I don't have the time to take it all apart and reassemble etc. That said is there any advice for trying to clean it out while it's on the vehicle...ie seafoam in the tank, carb cleaner sprayed directly into the fuel inlet on the top of the carb etc.
Thanks,
Tom
Thanks,
Tom
