99 900STX ignition problem...
Looking for some advice, search didn't help alot...
900 STX jetski with approx 200 hours. Ski ran great yesterday, wouldn't start this morning. Pulled the plugs, plugs are wet with fuel, but there is no spark. Checked all 3 plugs, no spark on any of them. Engine will crank, gauges all reading fine. Fuses are good. I pulled the cover off the box in the hull, everything looks OK. I'm guessing its either the crank sensor (or whatever signals the CDI box to fire, or the ignitor box. Is one of these more likely than the other to be a problem area, or is there something else I should check? Any advice on where the best place to buy parts is, other than a dealer?
Thanks,
ed hunter
Thanks,
ed hunter
