Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
96 kawasaki 750 sts
Old 07-22-2012 | 02:33 PM
trackside's Avatar
Default 96 kawasaki 750 sts
need some help here guys cant seem to get enough water through motor to cool enough in water runs fine on hose checked all lines n hoses no clogs just spurts out any ideas ps if hose is hooked under manifold it runs cool just not enough volume in water stumped here thank for any help
Old 07-26-2012 | 10:03 PM
OldGuy's Avatar
If a saltwater machine, the whole water jacket can get corroded enough to slow water flow. Otherwise check hose fittings. The hoses might be OK when you disconnect them, but a small pebble, or other debris can clog the fitting. this includes the fitting on the pump itself where the original hose feed comes off the pump for engine cooling.
Also, the water temp sensor housing can clog internally.
leach247
07-09-2011 09:29 PM
sparkdad
07-11-2009 10:42 AM
tjllm
05-30-2009 03:29 AM
jprickett
10-04-2007 01:44 AM
KBowers71
08-28-2007 09:20 PM
Quick Reply: 96 kawasaki 750 sts
