Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
95 750 zxi runs great but will not move
Old 08-03-2010 | 08:15 PM
kellymj61's Avatar
Default 95 750 zxi runs great but will not move
Need help I just was given a 95 750 zxi that will run great but will not move at all. Does anyone have any suggestions?
Thanks
Mike
Old 08-04-2010 | 06:11 AM
Prom's Avatar
Little more info would be nice. Can you put it in gear? If not does it just not go or does it die when you kick into first? if it diesdoes it lurch? If you can put it in gear what happens when you disengage the clutch? Does it die or lurch or nothing? If it does nothing what happens when you rev it?
If it dies your probably looking at a switch issue, usually a kickstand.
Good luck, and welcome to KF!
Old 08-04-2010 | 10:56 AM
kellymj61's Avatar
It is a jet ski not a motorcycle.
thanks though
Old 08-05-2010 | 03:02 AM
86chev6bt's Avatar
Is the propeller shaft spinning? There should be a coupler on the crankshaft of the motor that connects to driveshaft? There is usually a bolt used as a shear pin. If that is sheared off then the two couplers slide apart? need some more details to better diagnose?
Old 08-05-2010 | 03:05 AM
plus 1^
Old 08-05-2010 | 05:55 PM
kellymj61's Avatar
no the propeller does not spin. how hard is the coupler and shear pin to get to and look at?
Old 08-05-2010 | 11:20 PM
86chev6bt's Avatar
Just pull the seat off! You will be able to see the motor, coupler, and driveshaft will be on the back side of motor or the side facing the rear of ski!! All are direct drive! If motor is running the driveshaft and impellar WILL be spinning!
Old 08-08-2010 | 03:10 AM
Prom's Avatar
Oops, I forgot what forum I was in
Old 06-04-2011 | 06:02 AM
dannydoesithimself's Avatar
engine running driveshaft is turning but my impellor isnt turning?1996 kawa x1 super sport twin-carb 750
Old 06-07-2011 | 04:54 PM
OldGuy's Avatar
Danny,
First, you should have started a new thread. Its called "highjacking the thread", and its bad form (on any forum) when you tack on your own question at the end of someone else's discussion. Plus, this thread is old... no one is watching it anymore.
But just to help out, you need to check your pump. If the drive shaft is turning and the impeller is not that's bad news. Shaft is broken, impeller is broken, or probalby the whole pump body is swollen up and seized your impeller. Take the ride plate off, the intake grate off, and start looking to remove / rebuild the pump and/or driveshaft.
Good luck.
