Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
2000 Kawasaki 1100 STX D.I. dying problem
Old 08-04-2009 | 06:30 AM
SSThunder's Avatar
Default 2000 Kawasaki 1100 STX D.I. dying problem
I got the ski this year used. I noticed it missed at little at first when started and running at slow speeds. First time out she was fine and I rode her for 2 hours. Next time out after an hour she started missing and died. the problem got worse and finally it would barely run and kept dying. 3rd time out I encounter the same problem. After an hour of running good, the ski starts missing a little, then a lot and won't run. I find if I let her sit for an hour she'll run fine again for 30 mins then it starts dying again. I've replaced the plugs but I'm thinking it might be a coil or spark plug wire problem. Maybe something is getting hot and causing the misfire. Anybody have an idea what could be causing the problem??
Old 08-05-2009 | 08:46 PM
lambo2009's Avatar
sure sounds like the coil isbraking down try to check the spark when it shuts down on you good luck
Old 08-10-2009 | 01:49 PM
SSThunder's Avatar
I thought it might be the cooling system so I cleaned it out this past weekend. The jet ski gave me a code this weekend. eng9 popped up on the screen and that code isn't in my service manual and I can't find it on the web. anybody know what that code means?
Brennerw
05-31-2015 10:06 PM
SurfBeat
01-21-2015 02:20 AM
PerchLane
10-19-2012 09:59 PM
bwmechanicalinc
09-05-2011 04:19 AM
georgia12
04-26-2010 04:57 PM
Quick Reply: 2000 Kawasaki 1100 STX D.I. dying problem
