Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
1996 Kawasaki Jetski 750SS
Old 06-06-2009 | 05:51 AM
casanova's Avatar
Default 1996 Kawasaki Jetski 750SS
Hello to everyone,
Looking for some answers, Kawasaki Jetski 750SS, it don't start only with starter fuel it start when you stop spraying the Starter-Fuel it shutoff. clean the plugs, it pick up fuel from tank fuel line ok. where should i Check for fuel supply or what next to check. Engine will crank, it keep running with starter fuel spray but stop when i stop the starter fuel spray too. Fuses are good. what should i check? thank you ..........C.N
Old 06-19-2009 | 11:33 PM
hamtown's Avatar
Suggest you consider rebuilding the carb.
Old 06-21-2009 | 01:12 PM
solarpowered's Avatar
1. Verify fuel is available on the primary fuel line from the tank (siphon method). Fuel filter (metal) within the tank becomes clogged if fuel is not drained and left for long period of time.
2. Verify fuel pump is receiving vacum from the engine. Test the air line off of the front cylinder intake. Utilize a vacum meter.
3. Remove the carb from the intake manifold.
(air vent) straight bit screwdriver.
(air housing) (4) 10mm bolts.
(throttle cable) manually accelerate throttle so cable can twist to be removed through slot.
(Choke cable) manually full choke so cable can twist to be removed through slot.
(primary and return fuel line) remove from carb, ensure they remain above tank by tying them off to prevent fuel drainage into hull.
(fuel pump vacum hose) remove from carb.
(carb) bend metal retaining tabs and remove (2) 10mm bolts.
Seperate gasket from carb/intake manifold.
test fuel pump (suck/blow) into air port. fuel should leave carb through the return line port.... careful.
If not disassemble and inspect/replace carb components
thumper803
08-03-2009 05:00 PM
hermie
07-09-2009 01:24 PM
RyDWakE
06-24-2008 10:40 PM
89ezgo
06-04-2008 12:31 PM
t6788j1
04-01-2008 02:48 PM
Quick Reply: 1996 Kawasaki Jetski 750SS
