1100stx
RE: 1100stx
Your oil level sensor inside the oil tank is going bad - sticking. You may be able to clean the floats and try again. You can't really run pre-mix on your 2000 direct injection model because oil has to be delievered to the crankcase as well. The reason it goes to idle mode is because the ECU thinks you are running out of oil and it turns into the LIMP HOME mode.
