ZZR 600 Gas tank HELP
Old 06-23-2007 | 05:44 PM
antisniperspy's Avatar
Default ZZR 600 Gas tank HELP
Hi, Im new to the forums but I was wondering if someone knew anything about this.
I have a ZZR 600 which is brand new and I went to go get gas for the first time. I only had the RES left in the bike. When I went to get gas I filled it fill but it only took 2.6 gallons.
When I read the manual it said the RES was 1.1 gallons and the rest of the tank was 3.7. Does anyone know why it would only let me fill to 2.6 gallons at the gas station?
Old 06-23-2007 | 10:27 PM
zzrick's Avatar
Default RE: ZZR 600 Gas tank HELP
Did you actually run the tank out and have to go to reserve? And did you "top off" the tank when you filled it? Just asking, I haven't had any problems with mine, but sometimes there is more gas in there than you think.
Old 06-23-2007 | 10:32 PM
Yes I run the tank out and then went to the reserve.SO there should of been about a gallon when I went to the gas station. Then when I got the the gas station I did top it off and it only took 2.6 gallons. So I was really confused?
Old 06-23-2007 | 10:40 PM
zzrick's Avatar
I'm not sure then, maybe he just wasn't very thirsty.
Old 06-24-2007 | 01:56 AM
markmeinteil's Avatar
There is no way you'll ever be able to use every last drop of gas in your tank. Even when the reserve is gone, some gas will always remain.
Sonic*ninja
ZZR 600
10-05-2007 02:29 PM
crb987
04-18-2006 04:58 AM
poolhustler21
09-27-2005 12:48 AM
Gerg
ZZR 600
07-09-2005 12:49 AM
Gerg
06-18-2005 01:07 AM
Quick Reply: ZZR 600 Gas tank HELP
