zxr400 suspension
Welcome to KF
The "expansion bottle" should be just that. Using oil, a bladder with Nitrogen as the inert gas. The bladder is the separater, while the Nitrogen is pushed back and forth by the oils exertion against the bladder. Nitrogen will not heat up as bad/fast because it is an inert gas and is more controlled lets say.
If you need to rebuild the assembly, hook up with your favorite suspension tuner. Money well spent.
