zx7 engine swap
Old 05-07-2008 | 01:57 AM
yellowkow7's Avatar
Default zx7 engine swap
i have an 02 zx7 engine going into an 01 frame, but im having trouble fitting it any advice on neccisary modifications or anything that might make it fit? thanks
Old 05-08-2008 | 08:49 AM
whitehendrix's Avatar
Default RE: zx7 engine swap
no mods.. should lift right up in there..
make uber sure all your lock/alignment pins are wound out the wholeway. there will be one at the top motor mount on both the clutch and throttle sides, and one down by the swingarm.
shouldn't have to spin it or anything.. if you can get the lower rear bolt in, you should be able to swing the whole shebang up and into the frame then..
good luck!
Old 05-10-2008 | 10:43 AM
Never tried that yet. But since rides only change every couple of yrs, it should be a breeze to swap the engine and components on the 01.
Old 05-15-2008 | 08:35 AM
amen, Ted man..
yup.. everything from '96-'03 was identical.
Israel-klx250s
03-04-2012 08:33 AM
ElNinja10R
Ninja ZX-7R
02-06-2008 05:24 PM
Rydyr
Ninja ZX-7R
06-30-2007 07:54 PM
tlauhon
05-31-2006 09:04 AM
Dragon
09-15-2005 07:46 PM
Quick Reply: zx7 engine swap
