zx1000 float level
RE: zx1000 float level
Give this a try:
a -$1.00 glass tube antifreeze tester. take the rubber suction bulb off the top and let the little float ***** drop out. Then just plug the tester's vinyl tube into the carb bowl nipple.
Don't use a straight piece of clear tubing to measure your float level. The surface tension of the thin tube can offset your readings.
