Yoshi bolt on qustion
Hello,
I have a 2000 zx7r. When I bought the bike used it had a stainless exhaust. My buddy has a Yoshimura RS3 bolt on exhaust for sale, is there any way to make the bolt on work with the pipe set up I have? Please help Chris Thanks
RE: Yoshi bolt on qustion
The Yosh pipe probably will not fit on your mid pipe, if it does your good. If not you could go to your local muffler shop and ask them to make you an adaptor so the two will mate.
After wards you will need to check your plugs after about 50 miles and see if they look lean or rich. You may need to rejet to fix a lean or rich condition. Most silpons do not require rejeting but since the Yosh pipe is for a different pipe it may.
