What fuel does everyone run???
Old 04-27-2010, 07:12 PM
flux capacitor
Old 04-27-2010, 07:24 PM
Prom's Avatar
But you need a "Mr. Fusion" to power it.
Old 04-27-2010, 10:45 PM
Originally Posted by jeffzx9
I would suggest running the fuel your manual specifies. If you are spec'd for premium; run premium. You can run on a lower octane, certainly, but you'll likely burn more of it. You may also damage any O2 sensors or electronics (as Prom already mentioned^.) You can run premium if spec'd for regular, but probably no need or benefit.
Now, if you've significantly modified your engine and changed compression specs, I'd still suggest some testing data so you know WHY you're twiddling with what you're combusting. (Again; already mentioned^.)
Ask yourself: Are You Smarter Than Your Spark Plug Deposit? Get your facts straight before you potentially ruin your engine by playing "Shell Answer Man" and dumping E85 or B20 or Turbo Blue or some other go-fast potion into your tank.
I'm betting the KLX650 probably had 87 or maybe 89 recommended in the manual, but mine would detonate with 89. No way I'll run a low grade if the engine is "telling" me it needs higher octane by detonating, aka spark knock, preignition; an audible rattling in combustion caused by fuel explosions instead of burning or fuel ignites in different areas of the combustion chamber and the flame fronts collide resulting in that pinging sound.
I don't need some guy writing some manual that isn't riding or listening to my engine dictating what fuel I run. When an engine has detonation and all else is in tune I know what to do - go up in octane. Besides running excessively high octane won't hurt an engine.
Old 04-28-2010, 01:49 AM
jeffzx9's Avatar
You're right, KLX. My recommendation is partly geared toward the inexperienced folks who add mods without thinking, and when their bike runs like crap, they immediately drive to Wal Mart and buy Super 180 Turbo-Magic because hey; they have hi-po mods, now. The only thing left to f-up is the fuel!
Another common scenario is that many vehicles (cars and bikes) are factory spec'd ridiculously lean (or geared all wrong to pass emissions) and when their real world owners don't duplicate laboratory conditions (kinda like that 30 year house paint) surprise(!!!) that 87 octane doesn't work like it should.
Maybe I should have said "the recommended fuel octane spec is a place to start; a point of reference, to provide owners with a higher probability of duplicating measured performance and emissions under factory conditions."
As for excessively high octane not hurting an engine, I believe the farther away from optimal combustion you go, your engine will proportionately be damaged.
Old 04-28-2010, 08:21 PM
denaultd's Avatar
Default Gumout booster
Has anyone used an octane booster from gumout, or other company? If so was there any noticeable difference?
Old 04-28-2010, 08:31 PM
Dready's Avatar
93 octane..all day everyday
Old 04-28-2010, 09:38 PM
Prom's Avatar
The cost/benefit of using lower grade gas and adding the booster just isnt there, your better off sticking to the 93. As for upping the 93, you shouldnt need to. If you do happen try it, be aware its made for cars, so dont use the whole bottle in your tank.
Old 04-28-2010, 09:41 PM
greenzxr750j1's Avatar
i run 99 if i can .... the zxr seems to love it ... pulls cleaner ... but the 95 seem to run fine to ... depends on how much money i have lol
spara
08-16-2013 01:12 AM
JT@bikerperformance
04-28-2010 08:23 AM
kpwestmo
12-19-2009 01:57 PM
cmon6969
10-08-2007 05:29 PM
Quick Reply: What fuel does everyone run???
