Taking a bike apart to work on it.
Old 03-11-2009 | 06:32 PM
Metalcore's Avatar
Default Taking a bike apart to work on it.
Should I buy two wheel stands to keep my bike on while I am working on it? I don't want to invest in any kind of a work bench because I can't spend that kind of money, but couldn't I just use two stands and work on my bike with that? I know the bike needs to be straight up and down, and I don't have a center stand. Any input or suggestions would be great
Old 03-11-2009 | 07:40 PM
Here's what I got, I paid like $250.00 for mine, but I have seen them for around $100.00. Sears also has some jacks that will work. Here is what I have.
That way you can get it way up off the ground to wash it...because let's be honest, a clean bike is a happy bike.
Old 03-11-2009 | 07:41 PM
Wow that pic is old. I still had the stock pipe on it.
Old 03-11-2009 | 08:14 PM
OMalley912's Avatar
Now how are you supposed to put the bike up on that stand being that high? If you want to go a super cheap way, get a milk crate and a couple 2 by 4's cut to fit.
Old 03-12-2009 | 12:54 AM
You can also use heavy drill rod from msc or similar, and use two car jack stands. Most people have two jack stands. That method holds up a 10r with no issues for suspension setup.
edit: The drill rod goes throught the swingarm pivot and rests on the jack stands. You can work on both ends of the bike.
edit: Good drill rod will set you back about $13 for the stick, cut it to length.
Old 03-12-2009 | 03:35 AM
whitehendrix's Avatar
a stand is INVALUEABLE.
then again, i work on bikes for a living.. but trust me.. you'll wonder why ya never bought one earlier.
you can work on a bike without em.. i did it for years, but it really is soo much nicer rocking a nice stand out to work on stuff.
Old 03-12-2009 | 04:11 AM
Metalcore's Avatar
So you all think that what Deej has is the way to go?
Also, is there anything actually holding the bike to the stand? I'd be afraid with something like that, that the bike would not be steady when removing bolts and screws.
Old 03-12-2009 | 04:44 AM
for a down tube bike, it works good.
Old 03-12-2009 | 05:03 AM
Metalcore's Avatar
I wish I wasn't retarded and knew what that means, but I don't
Laments terms please
Old 03-12-2009 | 05:40 AM
oops, was referring to the upside down tube front forks
Quick Reply: Taking a bike apart to work on it.
