suping up the 92
suping up the 92
OK first off i wanted to thank everyone who helped me with my last problem. Ok I want to install a jet kit in my 92 ZX-7 and was wondering which one is the best (stage 1-3, i don't care), next i was wondering if anyone knew which plastics would fit on on my bike, i was thinking a 92 ZX-7R tail section and a 93 upper fairing because i like the single air scoop but i am going to assume that i am going to loose the intake function of the tubes so how badly is that going to affect performance. Other than that i am looking for anything i can use from later model ZX's to build sort of a mixed-breed bike with very little to no modding for the actual bike or parts. Im sorry if this sounds impossible, but thank you anyways.
RE: suping up the 92
Jet kit will depend on what other mods you have, full exhaust, and air filter etcetera. Check with Dynojet you can call them, give your bike info and they will recommend the correct kit.
I would not recommend going to 1 intake because you will probably be running very lean due to the lake of air flow. You can check and see if it is possible to install a single intake air box on your bike if so then you can use the single air intake that you like.
Not sure about the fairings but you can check out this site they have good microfiche and you can see the parts and compare them. Anything is possible. Linky
