Starter Clutch: '81 KZ 750 LTD (4 cyl)
I’m trying to remove the starter clutch to replace springs, rollers and caps
Got the exhaust system off. Got the clutch out. Got the oil pump out.
Got the secondary shaft nut off
Now - my “Clymer Manual” says to tap on the left end of the secondary shaft until
the right end pushes the right bearing out - done.
Now - it says to “pull the secondary shaft out of the clutch side of the engine”
The secondary shaft won’t pull out, as starter clutch and the starter clutch gear do not slide off of the secondary shaft
Are the gear and/or starter clutch attached to the shaft?
