Sloppy sounding engine, any ideas. Please read!
Hello, Just bought a zx6 1994 ninja.The motorcycle has 14,500 miles.
The engine sounds sloppy in it's lower end at idle or when not throttling. Not a knock, but like a sloppy sound. It runs good and as I said before the sound goes away when throttling. Any ideas? Thanks...
Regards,
The Rev. AC
Regards,
The Rev. AC
RE: Sloppy sounding engine, any ideas. Please read!
Sounds like another one of kawasaki's wonderful cam chain tensioners has crapped out on you. If the cam chain is loose due to a bad tensioner, it will sound sloppy especially at idle, and lower rpm's. You can replace it with another one, or, find a manual cam chain tensioner. Nothing beats the reliability of a manual tensioner. You just need to check it at every valve service interval.
SlapDrum
08-17-2009 05:59 PM
