Running without a fuel pump
On the old 2-smoke triples, there was a fuel block which separated into 3 lines to the carbs. No fuel pump. The bikes ran fine until you got into prolonged high rpm (in which case you were scared so bad you weren't thinking about fuel!)
Running without a fuel pump can be done for most pedestrian-type of riding. However, the guys above^ are exactly right about high rpm's and fuel flow problems.
I'd say run without a pump until you can get one. It won't hurt the bike, necessarily; you just won't be setting any lap records.
LOL you probably right about that... 32k miles and I have no idea what the previous owner did with it... I was reading through my manual and saw that the valve adjustment is basically one measuring tool you use and use the chart in the manual to determine what size shim to replace the old one with and remeasure... is that pretty much all it is??? how have yall faired with valve adjustments if you have done them yourselves???
What type of ride are you working on?
oops.
I like a timing wheel, along with a tdc stop, feeler gauges, torque wrench and new cam bolts since they like to stretch. Your favorite CCT (cam chain tensioner) tool will also be needed. I may add to this later since I am on a Memorial Run and am trying to keep this short. Good luck
oops.
Its a 95 6r with 32k lol...
grant1
03-27-2009 03:08 PM
