Rear turn signal
Rear turn signal
I just installed a fender eliminator and new aftermarket turn signals. The left one works fine but I can not get the right rear to function. Any suggestions? The right front still works with no problems. Any help is appreciated.
Out of interest, why did you change them? I found that a terrible problem with Eliminators is that the rear left indicator socket rusts away, as the bike leans to the left when parked I think all the water runs into it.
Thinking of LED ones for mine.
I didnt like the look of the stock signals and fender, wanted a cleaner sportier look for the bike. I will have to keep an eye on that though, didnt realize that would be a potential issue with them. Turns out the signal itself was no good. I swapped it with the other one and it worked fine and the I connected the original signal to it and it worked so its back to the dealer I go.
