Quick question
Old 09-11-2007 | 06:10 PM
mavriktu's Avatar
Default Quick question
I have been having what I think are fuel related problems.I removed the tank on My '96- Vulcan 750,and cleaned the filter(fuel) put it all together and it ran great-------for 5 minutes!.Now it wont start at all,is it possible to install this particular filter backwards???
Old 09-11-2007 | 06:42 PM
markmeinteil's Avatar
Default RE: Quick question
Welcome.
Check that your fuel petcock valve on the gas tank is allowing gas to flow when vacuum is created as the engine turns over.
Old 09-11-2007 | 08:18 PM
mavriktu's Avatar
Thanks,will try that ,-----LATER.I have had that tank on and off 4 times today and am about to put a match to it.[]It is now beer thirty o'clock and I quit for the day.
Old 09-11-2007 | 11:10 PM
jeffzx9's Avatar
Make sure the vent hole (very small) in the gas cap will let air get to the tank. Otherwise you create a vacuum and no gas will flow.
If you disconnect the fuel line (after the filter;at the carb) and turn on the petcock, will gas flow out? (5 minutes) is about how long it takes to "run out" of gas from your fuel line.
Just wondering....
Old 09-12-2007 | 02:42 AM
davehayward1's Avatar
If it is the petcock you can buy a rebuild kit
You'll replace the rubber gasket that's about the size of a postage stamp
Make sure the two surfaces that meet up with either side of this gasket are perfectly flat
If they're not -- file them down a bit
If any air can get into this seal it'll interfere with the flow of gas through the petcock
Old 09-12-2007 | 03:47 AM
ORIGINAL: davehayward1
I like the beer thirty, but
question? So you are saying the the seal is insufficient for long term use?
spooknick
02-01-2007 06:08 AM
joe sprocket
09-21-2006 05:47 AM
jds636
05-09-2006 06:38 AM
Fremont250
04-17-2006 02:09 AM
justin
02-11-2006 08:52 AM
Quick Reply: Quick question
