Question about adjusting valves.
Old 01-06-2007, 04:12 AM
mmi86's Avatar
Default RE: Question about adjusting valves.
if you use the bump method cam lobes should be pointing one to the east and one to west, very good method i forgot thanks kevyztoy, do you know the name of the tool thats used to lift the cam shaft to get the shim out
Old 01-06-2007, 04:25 AM
KevyzToy's Avatar
No I don't.My bike is shim over bucket so all I have to do is slide a rocker over to the side to get the shim. I don't have to remove the cams.
Old 01-06-2007, 05:37 AM
mmi86's Avatar
maybe one day ill find out the name of it, haha.
Old 01-21-2007, 03:40 AM
dogdragon's Avatar
Tip. If it ain't rettling, just leave it! Listen to your engine when it is running, use a stethoscope or a screwdriver and you can hear a eace tappet n rocker, if they sound louder than any other then one is worn or loosened. then think about it.
I can't answer much further than that, as like the lot above say, I don't know if it bucket n shims or ol' style rocker n tappet, might help if u let us know the mdel too.
Si
( www.dogdragons.com )
Old 01-21-2007, 04:37 AM
KevyzToy's Avatar
ORIGINAL: dogdragon
Si
Acually I would rather hear some tapping. If they are quiet, they could be getting on the tight side, and that ain't good.
Gecko
10-06-2010 06:17 PM
hancadam
04-02-2009 11:07 AM
open air
08-27-2008 03:58 PM
pitbull419
09-23-2007 08:13 PM
rickyzx
05-27-2006 11:35 PM
Quick Reply: Question about adjusting valves.
