a question.....
Old 03-11-2013 | 08:33 PM
brcree's Avatar
Default a question.....
Hello....I'm looking for info on a friends bike that needs some help. Its a 79 zr1100. I know nothing more about it except that he tells me that when he comes off throttle it has white-ish / gray-ish smoke out the pipes. Need to know what might be the cause. Carbs have been cleaned. Thanks for any info on this one.
Old 03-11-2013 | 11:47 PM
white smoke: Piston oil ring worn, cyl worn, valve oil seal damage, valve guide worn, cylinder head gaskets are damaged, engine oil level too high.
Welcome to KF
Old 03-11-2013 | 11:52 PM
brcree's Avatar
Default question
Thanks Dragone....I thought of all these as well, just looken for as many things it could be. The guy will will have to bring it by for me to look at. I've never owned one so.......I have a 81 Yamaha xs1100.....so i figured they might be close on most eng items.
Old 03-12-2013 | 12:16 AM
Right on, stay with the tried and true. Check oil level then a leak down test.
1stCruiser
04-23-2011 03:27 AM
fastex500
03-28-2008 01:41 AM
BlueDream
11-21-2007 05:35 PM
Quick Reply: a question.....
