PIPE QUESTIONS
PIPE QUESTIONS
HOWDY Y'ALL. I WAS WONDERING IF ANY KNEW THE POSSIBLITY OF A new Yoshimura rs-3 oval PIPE FITTING ON MY'05 ZZR600 WHEN THE PAPERS THAT IT CAME WITH IT SAY IT'S FOR A '96-'01 ZX-7R AND IT'S A BOLT-ON NOT A SLIP-ON. SO TWO QUESTIONS ARE; 1) AM I LUCKY ENOUGH FOR IT TO FIT 2) IS A BOLT-ON A PROBLEM OR WILL IT FIT ONAS EASY AS A SLIP-ONORCAN IT BE MODIFIED TO FIT? I KNOW TOO MANY QUESTIONS BUT ANY HELP WOULD BE GREAT. THANKS FOR WHAT EVER HELP I CAN GET.
RE: PIPE QUESTIONS
THIS IS WHAT I HAVE. http://www.exoticsportbike.com/yoshimura.htmTHIS HAS SOME PIX AND A VAUGE DISCRIPTION. IT SEEMS LIKE THERE IS A DIFFERENCE BETWEEN THE TO AND I'M NOT SURE WHAT IT IS OR IF IT MATTERS. I'M MOST WORRIED ABOUT IF THE ZX-7R EXHUAST WOULD HINDER PERFORMANCEOR CAUSE PROBLEMS FOR MY BIKE.
RE: PIPE QUESTIONS
look at the pic in the link, a bolt on is just a bolt on muffler that replaces the stock bolt on can and the slip on is a mid pipe and can and it slip fits togather. id say no to it working on your bike without major modifications that are not wirth the time and effort.
RE: PIPE QUESTIONS
SO YOU DON'T THINK THAT A NEW CNC FITTING TO MAKE THE PIPE FIT THE CAN WOULD BE DO-ABLE. THANKS FOR THE HELP EVIL. I'M NEW TO THE BIKE MODIFICATION BUSINESS I KNOW YOU CAN MAKE FITTINGS FOR THIS TYPE OF THING ON CARS BUT I'M NOT SURE IF THAT WOULD CAUSE PERFORMAMCE ISSUES FOR MY BIKE.
THANKS FOR THE HELPI KNOW I SOUND LIKE A BROKEN RECORD W/ DOWN SYNDROME.
THANKS AGAIN
THANKS AGAIN
RE: PIPE QUESTIONS
if you have access to a cnc and its not coming out of your pocket then you can make a new piece to go on the rear of the pipe and a mount for it and it will work. not sure of the performance loss tho as the 7 has more to flow so the pipe might be a tad less restrictive or theres a chance that there is no difference at all in the design.
MK1gti20v
09-14-2005 06:47 AM
