pilotjet
Old 04-11-2007 | 08:43 PM
greenhornet's Avatar
Default pilotjet
What exactly does the piolet jet do? I took them out and could hardly blow through them so I took a torch tip cleaner and kept working it until i got it through I thought it was just clogged or varnish buildup but each one was the same so I did the same thing to each one could I have made the hole to big? And if so could this cause a problem its on my 1980 kz1000 not my ZRX1200 it just snowed again so I havent put it back together yet but I got new intake boots new battery new air filters cleaned carbs all I need is warm weather now please let me know if you have any ideas on this if its ok or what could happen if the opening is to big you can see same dia. hole all the way through
Old 04-11-2007 | 08:54 PM
Default RE: pilotjet
They are in the idle and low speed circuit. Hopefully you did not make the holes too big!
Old 04-11-2007 | 10:04 PM
what if they are could that flood it out and foul the plugs should I replace them while I have the carbs off I think I have some old ones from another 1000
Old 04-12-2007 | 03:47 AM
You are the one who would really know if you oversized the bores or not. But you will find it hard to fine tune the carbs properly if you do not have a good foundation.
Old 04-12-2007 | 05:14 AM
Here's
[IMG]local://upfiles/3994/A6B5AAA048E149C6B574759A66B5859A.jpg[/IMG]
Old 04-12-2007 | 11:56 AM
markmeinteil's Avatar
You should be fine.
Old 04-16-2007 | 03:28 AM
I put my old pilot jets back in finaly got warm enough to put everything back together even used the starter button with new battery starts right up no kicking I love riding oldschool kaws I cut the baffle in half and put the end cap back in sounds so old school & mean did my first doughnut smokin the tire!
