PILOT SCREW ADJUSTMENT TOOL
Old 09-10-2006, 07:13 AM
Notstock's Avatar
Default RE: PILOT SCREW ADJUSTMENT TOOL
ORIGINAL: walight01
I know y they need adjusting, i'm just asking y its a PITA to use a reg screwdriver. I'm not following you on the idle pilot screws. aren't those screws meaningless except at idle?
I we are talking about he same screws with the springs, 3 of them, those are the ones you use to adjust the carbsync.
Old 09-10-2006, 07:16 AM
markmeinteil's Avatar
Those Idle air screws are mainly for idle, but they do make a noticable difference anywhere below 3-4k if they're not set right. When I rebuilt the carbs on my 750, The clymer manual didn't say what to set the air screw at. Nobody else I talked to knew either. So I had to mess around with them for a while before getting it just right. having that tool would have made life much easier. I know in the future I'll probably have to rebuild another carb, and I want that tool for the next time around.
Old 09-10-2006, 07:17 AM
walight01's Avatar
oh ok. i guess i'm lucky my screws are easy to get to. 2 on top and only one on bottom
Old 09-10-2006, 07:18 AM
Notstock's Avatar
Mine are set to the specs for the jet kits that I have installed and the idle screws are what you use to sync the carbs.
Old 09-10-2006, 07:20 AM
walight01's Avatar
i also have the idle screws set to the jetkit specs. I so need to do a carb sync tommorrow
Old 09-10-2006, 07:23 AM
Notstock's Avatar
ORIGINAL: walight01
You mean AF screws I think.
Old 09-10-2006, 09:33 AM
I think everyone on this post is being confused by each other! lol
Old 09-10-2006, 09:41 AM
walight01's Avatar
i confuse myself. were all talking about the correct screws I have a very small then screw driver I can use to adjust all the screw on the bottom, the top I can just use a reg screwdriver. how the hell to you make an adjustment without taking the tank off?
djchan
12-27-2012 01:47 AM
BR3668
10-22-2009 02:25 AM
RaceGass
08-13-2008 09:37 AM
FireCheifBike
800, 800 Classic & 800 Drifter
04-06-2008 06:55 PM
medic5100
08-01-2007 05:13 PM
Quick Reply: PILOT SCREW ADJUSTMENT TOOL
