oil tank
Old 04-13-2008 | 11:42 PM
adamharris's Avatar
Default oil tank
I have a 2003 kfx 400 and I was wondering if letting the fourwheeler stand strait up on the back bar for a period of time cause gas to run into the oil tank or could it be something else.
Thanks
Old 04-14-2008 | 01:10 AM
Default RE: oil tank
hmm, good question. Generally when the ride is new, a person would expect good sealing. But after time??? You know what I mean. Welcome to KF
Old 04-14-2008 | 05:01 AM
whitehendrix's Avatar
the tanks is the front on that on.. right? i just did a head gasket on one.. i think it was an '02ish machine..
watch that as well.. its a manufacturer's defect on the coolant passage and the material used.. it erodes quickly and lets coolant into the block. i think it was the water pump area.. i dunno.. hafta ask my customer.. it was a while ago.
anyways.. there should be no gas contamination.. i guess your stuntin it? doin apehangers and draggin the bar all day shouldn't be an issue.. my boy (also the customer..) stunts the hell out of his with no issues..
i'd really do a conp check. like i said.. the head gasket went with little warning on the machine i serviced, and that one part.. whetever it was, was so badly corroded (magnesium part) that it assited it the blowout i think..
that could cause gas to accumulate i think.. that, ora breather and carb problem.. i'll look into some stuff on that.. get some answers.
and welcome to KF!!!
Warren3000
10-27-2012 11:42 PM
adamharris
04-15-2008 06:11 AM
doughrek
02-03-2008 12:49 AM
kawi636
04-04-2006 09:26 PM
Quick Reply: oil tank
