oil light
Old 09-01-2007 | 07:00 PM
mat88's Avatar
Default oil light
i changed the oil ona 2001 ninja zx6r and now the oil light does not turn off and the sight glass is full.
what would cause that?
thanks,
Mat
Old 09-01-2007 | 07:15 PM
Default RE: oil light
Did you prime the new oil filter?
Welcome to the forums
Old 09-01-2007 | 07:23 PM
mat88's Avatar
no i did not. how do you do that if it is a horizontal filter?
thanks,
Mat
Old 09-01-2007 | 07:25 PM
I fill my oil filter about half way lets say before placing it on my 10r. If I don't, the light comes on.
Old 09-01-2007 | 07:27 PM
mat88's Avatar
if you dont fill it half way will the light stay on or does it turn off after a while cause i dont want to run it and have the motor blow
Thanks
Old 09-01-2007 | 08:07 PM
Ifthe pressure is not sensed, the light will stay on. I just try and save the cavitation issues and fi light by priming the filter. The light should go out though within a few seconds actually.
Old 09-01-2007 | 09:15 PM
aszrael1266's Avatar
The Dude
try reving a bike just a little bit. Like up to 3 or 4k to get the oil moving. when I did an oil change the same thing happened. I just bliped the throttle a couple of times and the light was off.
Old 09-02-2007 | 01:40 AM
mat88's Avatar
i did rev it up a few times and the light did not go off, how long did it take for yours to go off?
thanks,
Mat
Old 09-02-2007 | 01:43 AM
mat88's Avatar
i tried priming the filter and the light did not go off so i let it idle for a few seconds and the light still did not go off have you ever had that problem
Thanks,
Mat
Old 09-02-2007 | 02:40 AM
Not after the oil recirc'd, the light went off. hmm
Quick Reply: oil light
