oil in air filter
Welcome to the forums, Cobb! I think your PCV valve is stuck open. ![Wink](https://www.kawasakiforums.com/forum/images/smilies/wink.gif)
Seriously, do you have some kind of crankcase breather tube or something that is causing back pressure into your intake? I'm no expert on the vulcan setup.
Glad to have you aboard. Someone will assist you shortly.....
Gear up; stay safe.
Gear up; stay safe.
cheers jeffzx9
asked around about pcv someone suggested removing air filter for a bit and this seems to have solved the problem will see what happens when i put new filter in fingers crossed
YYY.GUY
03-29-2007 10:11 PM
