nothing happens when the key is turned
The kill switch turned to ON? Clutch pulled in or the stand out? Check the schematics. Power out of the switch to the safeties? These switches not allowing the power to go to your starter? Good luck and welcome to KF.
if u have no lights when key is on and you batt is fully charged then you need to find where you possitive batt cable to the solenoid there should be a master power fuse there check to see if blowin and if it is replace and try it if it keeps blowing it then your charging ragulater is bad hope this helps ya
andrewf991
05-18-2013 03:58 AM
Thad-deus Coan
09-14-2012 04:32 PM
Thad-deus Coan
Ninja 250R
09-13-2012 06:11 AM
