New and need some help!!
Hello, I have a 96 ninja ex 250 f I was wondering if anyone had some model specific specs? I was also wondering if you could help me with jetting? I live at 5500 FT elevation and I need to know what jets to use.
Thanks much!!
Thanks much!!
RE: New and need some help!!
i agree, the instructions with the jetkit will tell you if you need to fun different jets at higher elevation and they will be supplied. Getting a service manual is the best thing to do if you ever plan on doing ANY wrenching on your bike. Most maintance on the bike is actually pretty simple once you know how it works.
Is this the general specs you are lookin for??
Engine and transmission
Displacement: 498.00 ccm (30.39 cubic inches)
Engine type: Twin
Stroke: 4
Bore x stroke: 62.0 x 41.0 mm (2.4 x 1.6 inches)
Fuel system: Carburettor. Keihin CVK30 x 2
Valves per cylinder: 4
Fuel control: DOHC
Starter: Electric
Cooling system: Liquid
Gearbox: 6-speed
More details Consult a Kawasaki repair manual.
Physical measures
Dry weight: 138.3 kg (305.0 pounds)
Wheelbase: 1,400 mm (55.1 inches)
Chassis and dimensions
Frame type: Diamond high-tensile steel
Front suspension: Hydraulic fork
Rear suspension: Bottom-Link UNI-TRAK
Front brakes: Single disc
Rear brakes: Single disc
Other specifications
Fuel capacity: 18.16 litres (4.80 gallons)
Engine type: Twin
Stroke: 4
Fuel control: DOHC
Starter: Electric
Gearbox: 6-speed
Physical measures
maninthesea
02-02-2010 01:05 AM
LilMomma
06-18-2009 08:16 PM
