Need help with shift star kit install
Bike: 05 ZX6RR
Issue: Factory Pro shift star kit install
I installed the above part and cannot get the bike to shift out of neutral when shifting up. So the star is only moving to 1st and Neutral. I have not put any oil in the bike as I was making sure everything was working ok before I closed it all up. Any ideas as to why it wont shift into the higher gears?
This was in Factory Pros customer reviews.
How do you know that a transmission is shifting quicker and more reliably?
kinda goes with what we were talking about earlier. good luck
You can feel it when riding.- Even when hand shifting on the bench, it's easier to get out of gear and "snicks" into gear, rather than "clunks" into gear (yes, most Kaws won't shift into 2nd unless the output shaft is spinning :-)
punkenduro09
12-08-2014 08:28 AM
