NEED HELP!!! punctured hole in oil cooler
Old 11-02-2007 | 07:38 PM
chris636's Avatar
Default RE: NEED HELP!!! punctured hole in oil cooler
If i purchased a new one, how do I go about changing these out???? THanks again for your help.
Old 11-02-2007 | 08:10 PM
jeffzx9's Avatar
Not sure if you need to take off the headers; may be a tight squeeze. However, there is a center bolt that you unscrew and it comes right off. There are two hoses (if memory serves) that will need to be disconnected. You'll want to put a drain pan underneath to catch the run-off. (May be a bit messy.) Install the replacement making sure washers, gaskets,or spacers are correct (if any; check your old assembly,) reconnect your hoses, check the oil level and add to spec. Watch for leaks or seepage upon initial start-up; don't reassemble the bodywork until you're sure you're good to go.
That's pretty much it.
Old 11-02-2007 | 08:58 PM
booboo13's Avatar
You need two vise grips or clamps for the coolant lines. Just clamp them past the nipples unscrew them and unbolt the four bolts on the outside. The bolts are tricky to access with the headers installed so make sure you have a couple of sizes extensions, or even a deep socket would be very helpful.
Old 11-03-2007 | 06:02 AM
ORIGINAL: jeffzx9
Drag, yep; you're right. However, there is pressure inside, which would make me a little nervous if I simply patched.
Thin material or not, a good 10 minute TIG and prep? Definitely do'able for the price.
Old 11-03-2007 | 12:06 PM
Truckman's Avatar
agreed.A good prep and a competant weld shop will TIG that up in no time and prolly only charge you 20-30$$$$.
Old 11-03-2007 | 01:44 PM
kawi750r's Avatar
put a sticker over it, it'll add like 5-10hp and fix the problem. plus it'll look really cool.
wynn711
12-14-2011 02:09 PM
cosmopl
Ninja 250R
03-27-2009 09:02 PM
blane10
Classic Sportbikes
03-02-2008 08:25 PM
booboo13
10-31-2007 01:37 AM
puddin
07-22-2007 01:51 AM
Quick Reply: NEED HELP!!! punctured hole in oil cooler
